Question Kef Q900: what amp to pair with?
PieterG
99
105
220
It took me a couple of weeks or researching to realize i need help from people who know a lot more than i do... and that's you.
The situation -- I own a pair of Kef Q900 floor standers, which have been used as front channels in a (poorly configured) surround setup. I want to move these into another room and play stereo music through them, mostly from the streamer i intend to buy: the Cambridge CXN100.
The question -- What amplifier should i use to drive the Q900?
Online research gives me conflicting information: they are not difficult to control, yet their bass is tricky because the impedance can drop very low. Many sources suggest using a high power amp to overcome that, but others say it's unnecessary for anything except nightclub volume or extremely large rooms.
I do understand that maximum watts say very little about an amp's efficiency. What i don't understand is that pairing suggestions range from a modest Marantz PM6007 to a high power Rotel or Yamaha at 2500+ euros. I noticed that Arcam A15 is popular here, praised for its neutral character and ability to drive all but the fussiest speakers. I'd like to believe that.
The dilemma -- I picked the Cambridge streamer for its wide stage and detail, and i care enough to set it up in a room for critical listening. I like my music with breathing room between the instruments, plenty of detail. My goal is to have room filling sound that resembles my Fiio portable player with quality in ear monitors. However, i don't feel like spending twice the amount on analog amplification alone. If it takes that, i'm probably better off with a different amp and speakers.
Please, if you have good advice, i'm all ears. (Apologies for the poorly chosen pun.)
If you happen to have experience with Kef floor standers, that would be extremely helpful.
Thanks!
I had KEF Q5's , the sound was transformed when I fed them with a Rega Elicit-R amplifier (105W/Ch into 8ohms). Much better control of the bass etc with high levels of detail. Having a large available amount of power in an amplifier allows the amp to supply immediate large amount of current to the speakers when required, so its not just about how loud the amp will go !
Thanks!
They are easy to drive, manufactures recommendation is anything above 15W. Realistically, you probably want 30W+ so as not to work the amp too hard.
If you are in the UK I would take a serious look at an Audiolab 6000A. the mark II came out earlier in the year. you can get the old version for £299 in silver or £399 in black. it isn't that long ago they were getting five star reviews at £700. Great sounding amp with 50W per channel, more than enough for your needs.
Thank you @Din5 and @Fandango Andy for your replies. Much appreciated.
These are a perfect illustration of the conflicting information i have been finding...
vs.
For reference: online sources indicate my Onkyo AVR is comparable to about 90W into 8 ohms. That should be adequate power, but it's unclear from the specs if it can control current properly when the Q900 drop to around 3 ohms.
Yesterday i put my speakers in a decent position and played them with the AVR in direct mode through the front stereo channels only. With ample breathing room the bass isn't very powerful and the sound overall seems to lack body and and feels compressed/nasal (sorry - i'm not familiar with the terminology here).
I do like the amount of detail from the speakers, and the better speaker placement gives nice left/right separation. I hope this indicates at least that they have potential. Things improve for me when the volume goes up, but i need a good room filling sound at a level where normal conversation is possible.
Perhaps this update helps to get more targeted advice?
I do have for sale on eBay a lovely Gato Audio DIA 250s-NPM amp. It will drive most speakers, I had it hooked up to a pair of Audio Physic Classic 15s.
vs.
Din5 may have just found the alchemy of speakers and amp that are a perfect match. Either that or his original amp was terrible! Do you have a good local hifi shop that may be able to lend you a demo model?
Thanks!
Hi Pieter, first of all Kef Q900 is very good speaker, big piece of "meat" for good price. They are designed for mid to big size room and no problem with loud listening. And they work from 32Hz above. So they have a lot of bass. But...They are 2,5 way with 3x8inch bass driver. One is active or connected to crossover in speaker and rest are passive membranes. This speaker is also quite large. Yes, this speaker will work with some small amp like Audiolab 6000 or Marantz 6007 but not good enough. This speaker has substantial bass output but need a lot of current and control. Tip like Rega Elicit or Elex or similar Naim Audio (even used ones) is very good one. A friend of mine was using Kef R7 with some 20years old Bryston R60. What a good sound it was! Kefs are picky and demanding speakers. I recommend to think twice and try some amp at home before you decide.
Reactions: PieterG
I have no idea what's going on, but none of my replies to other replies are going through. I get an error saying my content is spam-like or contains inappropriate elements... 🙄
@BiggaJ I had to look up that Gato. It's a gorgeous design!
It certainly looks capable enough on paper, but on the wrong side of the budget i have in mind.
Reactions: BiggaJ
@Integralista what you say makes a lot of sense - thank you.
With some AI help i educated myself a little on electrical current, damping factor, and bass control. Apparently the solution to the Q900 resistance dip is high current, which not all amps are able to generate. For example, a NAD C389/399 generates about 26A while an Audiolab 6000A only reaches 9A. Interestingly, a Marantz 60n gets up to 18A , while it's only rated 60W into 8 ohm.
The math gives me some suggestions that should work on paper. I can factor in the listening distance and volume, but it looks like the high current is critical for bass control, especially at higher volume. Ideally i'd like to hook up my speakers to a couple of those, but i don't know if we have many shops in Belgium that offer this.
No need to disappear down a ‘rabbit hole’ of tech specs, though it’s very interesting.
A couple of replies above are both true:- your speakers don’t need a v powerful amp; they might sound great with a powerful one! I think you need a local dealer who will let you try something at home, with an option to return.
Your AVR is ok, but your description mirrors my experience of such amps, unless they’re a top of the range version. At least you have a point of reference now!
i think that some newer amplifiers let me a bit down and knowing that the speakers you refer are real good ,i´m not able to refer a new or recent amplifier because of my doubts as a performance to get the best out of your speakers, AV receivers aren´t at all my possible choice but a full on stereo amplifier the less power ones have the tendencie to heat up a lot and more power they do heat a lot but i think someone refered to Rotel amplifier, were without a doubt very good, but price wise ,i don´t know your budget but try to see what Rotel stereo amplifier brings to the table, so to speak . the two mono amplifiers with a control amplifier or pré are a better choice but as i said the price is too much , but you know better than i what is your budget to a new amplifier,
Also i´m a KEF speakers user but mine are mid 80´s the KEF ONE 80.000 hertz hyper tweeter some here might know them and sound good as it were before the joined adventure with Celestion to China, Celestion seems to have vanished
Reactions: PieterG
Hi @Rui thanks for your reaction, and nice to see there are more folks out there who like KEF speakers. It's true that Rotel amps are mentioned as a match for these speakers, either as a fully integrated solution or pre/power combination. The 1572 or 1582 would be on my list if it wasn't 2000-3000 euros.
I was hoping to solve this with an integrated amp around 1000-1200, but could be convinced to go a bit higher after a good listening session.
Rabbit holes are my job! (I'm a technical writer in the IT sector.)
I take comfort in the fact that you have had a similar experience. I'm going to reach out to a local shop that has a good reputation for supporting customers AND sells at competitive prices. If they'll work with me i can hopefully gain a lot of practical experience.
I feel like i've never unlocked the true potential of my speakers in 15 years. Or maybe it's unrealistic of me to expect that room filling sound can be as good as what i get out of my portable player with dual AKM DAC and balanced in ear monitors.
Reactions: nopiano
Speakers in any room are a very different experience to iems, but for me it’s far more enjoyable. For some, the immediacy of headphones can’t be beaten; I prefer to feel some impact on my body, which speakers can deliver.
Keeps us posted on your trials, and good luck!
Reactions: PieterG
Have you though about local 2nd hand market, you might find interesting solutions , this refering to Rotel also in early 90´s there was a Denon pré with two mono blocks ,sometimes they appear for sale and normally the sellers invite you to listen to it in their homes with their speakers, just a sugestion
Premise - I am not at all technically-minded but this "tickled" me a little - and wanted to check out my own amp max output (Rega Elex-R) as well as a couple of amps I am looking at as potential future upgrade (incl. Naim Supernait 2).
I had a look around and I can see the 26A figure for NAD is at 1ohm, while the Rega says 6.8 at 8ohm or 9 at 4ohm. For the Supernait I could only find a generic 16.5A... How do I navigate and standardise these so that I have a reliable benchmark for comparison?
Reactions: PieterG
You can't assume that 100W into 8 ohm automatically translates to 200W into 4 ohm and 400W into 2 ohm, because this would imply the amp can deliver twice or four times the current (amperes) at the lower resistances. I don't know if this is related more to the power supply limitations or the design choices for sound quality - likely a combination of both.
Realistically, if you want some kind of benchmark to compare brands and models, i think you should rely more on the amp rating at 4 ohm if the spec sheet provides it. The typical watts into 8 ohm are a decent initial indication of power, but if the wattage into 4 ohm is significantly higher, that points to strong and stable current delivery. In theory you want to see twice the power at half the resistance, but that would heavily stress the power supply and generate a lot of heat.
Here's a little comparison table. It's similar to how i've been searching for models that might be a good fit for my KEF speakers. These are 5 well respected models, known for good current control and excellent rendering of quality sources.
Amplifier8 Ohm spec4 Ohm spec
Rega Elicit Mk5105W (3.63A)162W (6.37A)
NAD C399180W (4.74A)180W (6.71A)
Arcam A25100W (3.54A)165W (6.42A)
Hegel H12075W (3.06A)120W (5.48A)
Naim Supernait 380W (3.16A)130W (5.70A)
The outlier is the NAD: it's rated at the same power for 8 and 4 ohm. This is more likely a good thing, as they might focus on 4 ohm stability rather than very high power ratings. The 180W is obviously very respectable and higher than the others at 4 ohm.
The other 4 have a clear jump in power from 8 to 4 ohm, suggesting very good power supply engineering. Of course, specs are just numbers on paper. They say very little about real life performance, and absolutely nothing about how good they sound to an individual's ears.
The Hegel and Naim (@Entrigo is considering) have the lowest power in this list. I find this remarkable, because Hegel is known for power delivery and damping factor. The Naim Supernait is known for excellent speaker control and handles peaks very well - it's in a higher class than the others in the list.
My takeaway from this numbers exercise (which i enjoy because my brain works this way), is this:
  • Watts into 8 Ohm = how loud can i play this thing?
  • Watts into 4 Ohm = how well does this thing control my speakers?
  • Engineering/design = real world performance, i.e. accuracy, tonality, ...
Unfortunately that last one probably can't be properly benchmarked. It's definitely not something you'll find in the spec sheet.
TLDR; check specs for an indication of technical capabilities but audition equipment before you buy... which is nothing new to the people on this forum, i bet.
Reactions: Entrigo
Thanks for that, really helpful. Yes I had realised the output at 4ohm is never just double that at 8ohm but was a bit puzzled how to compare the max output you had mentioned - as some amps specs mention it (or it can be anyway found) and others don't.
I see you included aome ampere figures in the table above - but they don't seem to match the peak output figures I had found - especially the Supernait was quoted as having a peak output of 16.5 (unless this, like the NAD) was measured at 1ohm? And if so, should I then aim to find what the 4ohm figure is for all - given the main reason for the exercise is to determine the grip on the speakers rather than the volume (I live in a terraced house and have a medium sized room, so volume rarely if never goes above 75-78dB at 2.5 metres - which if I remember correctly from past calculations, means I only really need 25/30w).
As per demo - I am of course aware of the importance (especially as a regular user of this forum, where "just demo it" is the n.1 response to anyone asking for opinions on any component - especially from certain users). But:
1. I tend to buy used whenever I can (I suffer from Gear Acquisition Syndrome /upgreadeitis, so I am likely to change components often). And demoing used gear is very tricky.
2. The first time I did a proper demo, I walked away feeling a little underwhelmed by the component in object (Focal Aria 906). I then ended up buying them anyway mostly as they were the only front ported speakers I could find new - once home, and after the customary burn-in period, they sounded much better than they did in the shop, despite my room being much less "acoustically perfect" than Richer Sounds listening room. That experience honestly made me a little sceptical of the whole demo proposition. Unless you can do it in your own home, with the exact same setup and listening conditions, I don't see auditioning /demoing as the one and only reliable method for choosing HiFi gear as most people seem to consider it.
Disclaimer: i am not an expert by any measure. What i say is based on a lot of searching and reading, and very little personal experience. I have never listened to any of the amps in that table.
The watts i quoted are based on specs found either in manufacturer docs or reviews that mention them. The amperes are calculated from the watts at 8 and 4 Ohm resistance. These are not maximum currents, but probably currents sustainable over a longer period of time. If an amp generates more Amperes for short bursts, it means it can respond quickly to frequency and volume variations, i.e. peaks. If the amp has headroom in Watts and Amperes, my interpretation is that its control over the speakers is very good.
I may have dragged you down into my rabbit hole here, but i thought i should clarify what i believe i understand. Some people on this forum will have a deep understanding of this, and i would be grateful if they weighed in. If i'm talking rubbish, i'd love to be corrected.
Also, i'm with you on the auditioning part. It's not that easy to translate your experience in a shop to your home setup. Contrary to you, i'm afraid of buying second hand because i don't know how to judge quality or detect defects, wear, etc. (I'd be more comfortable with used gear in an area i do know more about, like photography or bicycles.)
Reactions: Entrigo and Al ears
I think you and @PieterG have misdirected yourselves in trying to fathom current capability in amplifiers.
Best look in reviews from Hifi News and Stereophile - online or paper journals - to see lab tested current capabilities. However, in general terms the table Pieter set out is simply maths. V=IR was Ohm’s Law when I was a school. Volts equals Amps times Resistance in ohms. Everything flows from that, as it were. (Such as Watts = Volts x Amps)
What you’re looking for is indeed peak current. Any amp producing, say, 100 watts into 8ohms will by definition be drawing the same current regardless of the spec. What is relevant, especially with low impedance speakers, is that the lower impedance draws the greater current from the amp. That’s why low impedance speakers, somewhat counterintuitively, are the hardest to drive!
Peak current is tested in the lab using a short-term signal. But, logically, the greater current available the greater the output into any load. Bear in mind that many amps deliberately engineer a current limit to prevent damage to themselves.
I hope that makes some sense. Doubtless Google or AI would have explained it better! 😱
Makes sense @nopiano. The watts in my table should be accurate - the current was calculated. I wanted to show real life sustained power at 4 Ohm because i think it matters more for speaker control and stability.
My interpretation - which may be wrong - is that an amp with max current well above what it needs at 4 Ohm, will be better at handling peaks. Max current is rarely found in spec sheets, but sometimes in detailed reviews/tests.
If there is another typical spec value that indicates good handling of peak power (specifically low resistance high current situations) then please enlighten me. Maybe i've completely missed something obvious, but i thought max amperes would be pretty good... if it were on spec sheets in the first place.
Reactions: Entrigo
Hmmm it will make sense once I have read everything from Pieter and yourself another 32 times 😬.
I have always been a man of letters much more than numbers. Hence while I crave more knowledge in the technical aspects of this wonderful hobby, I find it so very hard 😂
I think you may be overthinking this. Your speakers aren't hard to drive, the are a hundred and one amps out there that are going to go s job. You are not going to find which one sounds best to you on a spec sheet, or table of power ratings. if you can get out and audition them, that is always the best option. if you can't reviews are your best option.
Absolutely, peak current output does indeed convey the amp’s capabilities for handling the most demanding music into challenging speakers. That could be when the minimum speaker impedance is 2ohms in the bass region where brief very powerful sounds might exist on a recording. But sustained power output will always have an identical current into a given load, simply due to the maths.
Domestically, I don’t think one needs much more than around 10Amps into typical 4ohm speakers, but it’s relatively easy to find amplifiers with two or three times that for say £3,000 or less. The Denon PMA-3000ne and Exposure 3510 are two that come to mind. Both can produce peak outputs around 700watts into 1ohm!
Reactions: PieterG and Al ears
