Subwoofer - what should i do
modemfish
Hi i'm looking to add a subwoofer to my system.
Current set up is i have two kef LS50's hooked up to a sonos system diven by a sonos connect amp.
So my thoughts have been - buy a sonos sub or perhaps a used B&W PV1 budgetwise circa 500-600 GBP.
I would like to add a little extra kick (bass wise) to the system/
What would you do. Or would i get better improvements via a better amp source - i.e Sonos coonect to DAC to better amp.
Certainly if i went this route then the Sonos sub is out.
Looking for suggestions.
Thanks Mike
RobinKidderminster
582
Agreed. Back in the day where hifi spks uswd 12in bass drivers no. But modern slim designs will always struggle to create that depth
Joshuamessenger
11
If you was looking at dropping £600 I would get REL T5/7.
if you look around on the net you can get them, link below
http://www.petertyson.co.uk/ebuttonz/speakerssubs/subwoofers/rel/index.shtml
bretty
248
It'd be a sub, for my money. I think everyone that has the room for one, should have a sub. hi fi speakers on their own, whether standmount or floorstander, don't have the ability to create the rich, deep, textured sound of real music. They need the help of a well-integrated sub for that.
matt49
81
31
18,570
Thanks Mike
I'd go for a better amp. The LS50s are by all accounts outstanding speakers (I haven't heard them) which will give you big rewards if driven by a high quality amp. I've heard of people driving LS50s with amplification costing getting on for £5000+. With a better amp you'll probably find that you won't need a sub. Another advantage of improving the amplification is that you'll get more clarity and detail in the top and mid-range too. A sub won't give you that. You could even devote all your budget to a power amp and use the preamp stage of the Sonos Connect. I did this experiment last week, replacing my Sonos ZP 120 (= Sonos Connect in old money) with a ZP90 going into my Cyrus X Power. The difference was night and day.
If you're happy to buy second hand, you could find a decent Audiolab or Cyrus power amp (common as muck on eBay) within your budget.
BigH
142
19
18,595
Thanks Mike
I really don't think you will get deep bass from the LS50s and yes I have heard them, they have 5.25inch drivers and cabinets are not large, frequency response is 47Hz–45kHz. The main complant of the LS50s is lack of bass.
So my rec. is get a sub if you want deeper bass.
Overdose
279
An amp will not create bass that was not there before. A 'better' amp will only tighten up the bass, so the bass might appear to have lessended due to decreased 'boominess' and that is only if the existing amp is defficient.in the first place.
The KEFs are presumably good speakers, but they are still small monitors having the limitations of their design and would not be designed to give exceptionally low bass anyway, only as accurate as possible down to a certain frequency point, so they would benefit by having a sub to finish off the system.
I would echo other posters views that a sub is almost essential in a lot of systems with smaller speakers, if a full frequency range is required.
A word of caution though, subs can be tricky to set up and positioning can be critical to avoid unwanted areas of bass reinforcement or null points.
matt49
81
31
18,570
Yes, this is precisely my point: the amp (the Sonos Connect) is "deficient in the first place", because it doesn't deliver sufficient power or provide suffieicnt control to drive the speakers at lower frequencies (or at higher ones, for that matter). My post was based on my own experience of replacing the power amp stage of the Sonos Connect with a significantly better power amp.
I speak as a happy Sonos owner of many years: Sonos does some things brilliantly, but the power amplification isn't of hi-fi standard.
You also need to think about the effect of adding a sub to this set-up. You'll end up with decent low bass, but the rest of the frequency range, from mid-bass up to the top end, will be a mess: an fine speaker driven by poor amplification.
BigH
142
19
18,595
I see what you mean then a audition is the way to go then. I would try a Creek A50 which is about £700, if that is too much then maybe a Pioneer A50 £500.
matt49
81
31
18,570
[/quote]
I agree: it'll be an interesting experiment to audition the amp solution and the sub solution against one another.
Another option would be to connect the Sonos's analogue outs to a power amp. Candidates in the OP's budget would be the Musical Fidelity M1 PWR or the Audiolab 8200P.
The_Lhc
1,176
He has a Connect:Amp, it doesn't have any analogue outputs. It does have a subwoofer out, so you could audition a Sonos sub against a non-Sonos one.
Overdose
279
I can't comment on the amplification quality of Sonos, but even if it were lacking, the sound from the KEFs would if anything, appear to have more bass due to lack of control over the bass driver in the KEFs. They would sound 'woolly' or boomy. A better amp (and I'm not suggesting it doesn't need one) would only tighten up the bass, not give a deeper response. That is only going to be achievable with bigger drivers, ie a sub.
Edit: In addition, using a sub with the Connect amp, might give the system a bit more headroom with the KEFs, but I don't know if there is any sort of frequency cutoff going on in the Sonos to allow this to happen.
matt49
81
31
18,570
I stand corrected! I was thinking of my ZP100s, which do have analogue outs.
matt49
81
31
18,570
Agreed. The OP's words were: "I would like to add a little extra kick (bass wise) to the system". I guess my eyes were drawn to the word “little”.
The_Lhc
1,176
Yes, I've always thought it was an odd decision to remove them from the ZP120.
Overdose
279
Yes, mine were drawn to extra and bass. :p
The_Lhc
1,176
Certainly adding a Sonos Sub will cut off the lower frequencies. I'm reasonably sure that plugging a normal sub into the Connect:Amp subwoofer has the same effect. I'd have to double-check that to be sure though.
Overdose
279
If so, that in itself would give improvements to the drive of the KEFs alone, allowing the amp in the connect to be offloaded of the heavier work of reproducing bass below the cutoff. I noticed this improvement when using a sub with my monitors, but they had a physical switch to choose cutoff frequency for sub integration. Presumably the Sonos sub would be optimised accordingly?
recruit
Adding a sub will certainly open up the lower octaves, I am not usually a fan of Rel subs but when it comes to HiFi they have some of the best connections for intergrating the speakers and sub together, it might be worth looking for 2nd hand subs as some of there older ST subs were great and would probably come in well withimn your budget.
The_Lhc
1,176
Yes, all fully automatic, although manual adjustment is available.
Overdose
279
Hmmm, nice.
relocated
74
The other sub you might consider would be BK. I haven't owned one myself but I have never come across anything but praise from owners.
The Sonos route sounds like an integrated solution but i wonder whether a BK would be better in absolute terms and if you later decide to get a different amp for the Kefs.
Trouble with wanting a little bit more of this or that is when do you stop. We've all been there at one time or another.
Good luck and let everyone know what you end up doing and if it satisfies you.
Kevin Stephens
33
On a similar vein I'm considering a good ex-demo deal on a B&W ASW 700 sub to underpin my GS10s..
Is this likely to be a good idea with my amp? I'm not a bass hound and don't watch much TV, However I am looking to increase my enjoyment of a wide range of classical, rock and accoustic music
modemfish
A big thanks for all the replies. you gave me plenty to think about.
In the end i opted for Sonos Z80 > AudioLab mdac > Temple Audio monoblocks > Kef ls50
The added dynamics and range has solved my problem... :)
