subwoofer cable
danwhite0085
11
I have the dali zensor 1 5.1 home cinema system with the e9f subwoofer. I have a bog standard subwoofer cable and was wondering which cable I should upgrade to. Any suggestions guys??
Bog standard is fine. I've got this for my setup:
http://www.amazon.co.uk/gp/aw/d/B00FQK31DW/ref=mp_s_a_1_3?qid=1429636471&sr=8-3&pi=AC_SY200_QL40&keywords=kabeldirekt+subwoofer&dpPl=1&dpID=41WJ32UTK4L&ref=plSrch
I am personally a big fan of the QED Signature subwoofer cable - its a very well made dual screened cable which if you think about it a sub woofer cable is a multiple metre antennae and therefore a good screen is a good thing.
However a sub cable will not improve your bass response or timing to a large degree so make sure you have these nailed down first 🙂
the one you put on the link from amazon.
there might be something else you can help me out with mate.
all this is brand new to me and there's so much to learn!! my music libary is pretty much on my smartphone.
i have a few albums on there which are flac files but my system doesn't seem to play them. is it my amplifier? i have the
yamaha RX-v675. is there anyway around this so i can play my entire libary on my phone through my system. i want high qaulity files to play through it as well as the others.
