gasolin said:davedotco said:gasolin said:no choice.
If i use an eq i would enhance the bass from my bostons and my subwoofer.
I do need to lower the level of my subwoofer so i can't hear it and then turn it up and listen and then again up or down and listen until it sounds right, after that i have to listen to different music edm,pop,rock,jazz old and new recordings to hear if the levels is okay.
I just can't do that because my bass is somtimes a few db to loud and somtimes it's okay.
It sounds good,just not perfect if the bass levels is a bit to high then i can't turn the volume up until it's about the level i like
Try some of these.
http://www.rothwellaudioproducts.co.uk/html/attenuators.html
Not cheap but they give 10dB of attenuation and are supposedly inaudible.
Might just be what i need, they are out of stock on there homepage on the -10db version, need my volume on my sub to be to low-perfect- to loud, somtimes it's okay sometimes it's to loud.
Yes it's expensive,but what can you about that, i mean youit to sound good so you hyave to pay what it costs, i found it on amazon so now i just have to wait.
A high pass filter (around 80hz) is that difficult to get for my system?
Not difficult but expensive and complex. Simple answer, return the sub and try something with more control.
Music store in Germany are selling refurbished Adam Sub 7s for a little over €300 inc shipping. Decent small sub with built in 85hz filter for your Bostons.
