For anyone who has a Stream X or X2, I can heartily recommend the Stream X Signature (which can be had for about £300 in a factory return upgrade). But I'd also recommend it as a first purchase for someone moving into streaming.
Got one new on Saturday and swapped things around between my two systems with a Stream X2 I already had.
Compared to the standard model, the step up in SQ is significant. It is pulling as much if not more detail as the CD T ... but also with a fullness and warmth to the sound. I have no real idea what causes the improvement but there is an obvious 2.5 kg of extra weight in the Signature model. So more than likely all the key components are beefed up / or just simply added to improve the data retrieval and decoding.
It's still burning in and just getting better with each passing hour.
I'm well pleased with it.*yahoo*
