Not sure if I have started this in the correct forum.
I have both these streamers available and want to make a comparison.
Basically is it OK to connect the Sonos Connect coax or optical output into the coax or optical input of a Chord QBD76 DAC at the same time as connectiing the Cyrus Stream X Signature coax output into the other coax input of the Chord QBD76 DAC? If so I could compare the same track by using the Sonos app then stop the Sonos app then switch directly to the Cyrus cadence app. Music will be streamed from one or more WD NAS drives through a gigabit switch.
