Squeezebox App not compatible with IOS 6 on Ipad
def lugs
39
Is anybody using the Logitech Squeezebox App on the Ipad with Ios 6. Since the update which I did at the weekend on the
Ipad the app does not function correctly.
Is this unique to me or does it affect all users?
def lugs
39
I have closed the program and switched off iPad and restarted.
The app appears to be stuck on the last track I played before the update. If I select a new track it will play the new track but if you press any control to skip track or pause. The screen jumps back to the original track and the app freezes.
smuggs
347
i think i spent around a tenner for squeezepad app it its awesome cause it lets you set your ipad as player you can play different songs or sync the 2 up. I had the logitech on was poor and i could not in large the artwork on the ipad.
