Hi, apologies if this has been covered before but if it has I can't find it.
I have a quite large set of vintage Mordaunt Short Pageant 2 speakers, and I've just picked up some QED Tristands for them. They look really cool! This is a low stand made from welded steel box section in a tripod shape as the name suggests. They have holes for spikes for both the floor and under the speaker.
As title says I have less-than-ideal laminate flooring, with concrete underneath, and had a plan for the stands:
Fill with sand as much as I can and spike the tops into the speakers and the bottom into an Argos granite chopping board. Sorbothane/similar between the chopping board and the floor.
Does that sound OK or does anyone have any better ideas? (Other than get a new floor - not an option at the moment)
