Hi, I’m just replacing some Cyrus amplifiers with a Hegel H190. Ordered but not yet received it.
My current speakers are Focal Aria 906 on focal stands. I originally chose these because my room is quite small at 4m x 3m, and these were large cabinets with front firing ports.
Anyway, I was wondering for some advice as to whether the vocals go with the Hegel well? Or if a speaker upgrade should be considered.
Other speakers I’m considering include the Kef R3, Kef LS50 Meta, Buchardt S400, Amphion Arhon 3S (if I can get them used or ex display). Looking to spend £1000 to £1600.
Would prefer something with good bass reproduction. Typically listen to rock, dance, pop, rnb music.
the Hegel h190 will stream music directly from my Mac using Audirvana. Typically most of my library is lossless with some hi res audio.
I’m ideally looking at speakers that can be placed a maximum of 30cm from the wall and maybe 50cm from a corner of the room.
Any suggestions, opinions or experience is much appreciated.
