Speaker position
Martin100
18
Hi every one please can any one help, were on the web can i find a diagram of 5.1 speker position in a room, oblong in shape and the TV in the corner?
Martin
Andrew Everard
1,878
Front end is easy - centre under/above the TV, front left and right speakers to either side of the set. Where is/are the viewing position(s), and what are the speakers you'll be using on the rear channels?
Martin100
18
The speakers are Mission FS2 NXT Flat speakers, front and rear. The TV is in the corner and the viewing position is along the long wall opposite.................. Hope that helps as i need help!!!!!!
Martin
Andrew Everard
1,878
Then rears either end of the wall behind the sofa, mounted a bit above ear level.
Due to the dispersion characteristics of NXT panels, positioning isn't so critical, so they're a very good choice for this less than ideal - but of course very typical - layout.
Enjoy...
Martin100
18
Morning, so Maplin speaker wire is o.k, as i am trying to keep cost's down. Like every one i want a Rolls Royce with Mini Cooper money.
Best mention that the kit i have is;
Sony KDL 40X3000
Sony BDP S1E
Sony STR DA5200ES
Sky HD
Monitor Bronze BR5. For use when listerning to audio CD's
Mission FS2 NXT
All connected via HDMI cables
Martin
