Speaker cable
the record spot:322 strand. £5.49 for 10m, Digitalis Direct. Give it a whirl!
Hi the record spot
It might also be worth considering trying/using some 500 or 700 strand cables as i feel they are quite a bit better then the good 300 strand. These also tend to be very modestly priced.
All the best
Rick @ Musicraft
JoelSim:I have Atlas Hyper 3.0, one of 5.5m and one of 4m, cost me £102. So I'm considering selling these on and using the money to fund the purchase of a much shorter set of better cables.
What are the sonic traits of the Hyper 3.0 Joel? When I upgrade my S.A Bi-wire, I'm thinking of the Hyper 2.0 (don't know if you've compared the 2.0 and the 3.0), but then I also fancy checking out the QED Revelation, both of which are around £15 a metre. The QED is white, which would suit our decor better (or it will do when we get round to decorating), but the Atlas Z plugs are BFA compatible, (Airlocs aren't), which means I don't have to spend out on banana to BFA adaptors & worry about another 'chain' in the link from amp to speaker.
The other advantage to the QED is knowing that I am very happy with the sound I currently have, and the pricier QED should have a similar sound, albeit with less of the weaknesses of the S.A. The Atlas on the other hand are an unknown entity.
Cheers.
Big Chris:
From what ive read, the 2.0 is more natural sounding, the 3.0 seems to highten treble
