help ive got a dilema, im trying to match up speaker cable to the following set up, cyrus 6se cd to roksan k2 amp to audiovector m3 signature speakers, cables = ive got two true colours contrictor power leads, and using a ecosse nu diva interconnect. when i bought the cyrus 6se, the seller mentioned to me that the set up sounds best with ofc speaker cable, giving me the tip of chord oddassy 2 speaker cable. and that i shouldnt run the set up on anything silver coated or qed silver or x tube. well ive got xtube 400 speaker cable, i thought id give it a go anyway due to how mcuh it cost me and to be fair im the one listening to it. my findings are so fair, its a very detailed airy sound, giving good trble mid and bass, but can be a bit bright on certain tracks, and also bass can get quite thick. ive put posts on here asking for advice and been told to sit tight and keep listening. or try cheap cable or borrow some cable from local hi fi store. well ive got some van den hul cs122 cable from a few years ago that was replaced by the qed xtube cable. after having a evening listening to the van den hul cable my first impression is that its less bright than x tube, very detailed in places and on certain tracks, but the mid suffers and also the bass. i almost felt like i would like a hybrid of both cables, keep the musical feel of the van den hul but gain the bass and mid of the xtube. the van den hul played complicated tracks well (e.g.jacksons scream) and played a few tracks off tracy chapmans album with a very tap the foot fashion. but other tracks like pink floyd devision bell sounded flat and i know ive heard it sound better than that. so after all the blah blah, has any one got an idea of what would be a good speaker cable to achieve what i want to achieve which is musical spacious airy sound with detail and controled but good bass with the mid not being forgotten, and also not adding a bright after taste. anything from 15 - 25 pounds a metre is my price range. would like to hear any thoughts, especially from fellow cyrus -> roksan k2 -> floor stander speakers owners. thanks for reading the above
