Entrigo
104
47
18,620
Hi all,
Been thinking for a while about upgrading from my internal phono current set-up.
Tried the Rega Fono MK5 and, while good, I didn't feel it provided enough of a step-up from either the Technics SL1500C or the Marantz PM7200 own. Also found the highs a little softer than with the Marantz (and similar to the Technics).
So, now looking at different options and, after considering a fair few (Musical Fidelity MX Vynil, Moon 110 LP 2, Dynavector 75), I kinda landed on the Spartan 20.
Reasons - from what little info I found, sounds it might be more neutral and a bit punchier than some of the above - and with a warm and relaxed amp, wanted the phono inject something different into the mix. I also like the sound of the LF Xfeed option to reduce surface noise. And finally, I like that it's hand built and sold directly, so no middle man mark up - so hopefully better VfM.
In short - has anyone tried this? Thoughts?
camcroft
Hi all,
So, now looking at different options and, after considering a fair few (Musical Fidelity MX Vynil, Moon 110 LP 2, Dynaudio 75), I kinda landed on the Spartan 20.
Spartan phono stages are excellent. I have the 10 on my main system and the 5 on my second system. Not many people on this forum are familiar with the Spartan phono stages.
Reactions: Al ears and Entrigo
From what I can see the 10 is now discontinued and replaced by the 15 which is actually cheaper.... Sounds good. Like the inclusion of a mono switch.
The 20 looks good for the money.
I have never heard one though.
Reactions: Entrigo
Entrigo
104
47
18,620
Yeah that's what I thought. Sadly there's none in shops to demo - or on the used market, but hey, just thinking about what it might cost in a shop with the standard retail mark-up, it's worth it.
Yes the mono switch sounds good, though I don't really like mono recordings, so always try to find the earliest stereo one (for the few "mono-era" artists I listen to).
Entrigo
104
47
18,620
Another good upgrade for your cartridge is the RigB ( Solid body ) and it can be fitted to your present cartridge.
What's that? Well I was thinking my next upgrade could be an MC cartridge...
Or it might be a tonearm if the slight crookedness/ slant of mine is indeed an issue and one that can't be fixed at a reasonable price 🙄.
