Before I start,please note that this is only a quick review etc,
This Sony is very good LCD,It ouzes style and class,
The default settings are almost useable,not like some makes that come with
brightly lit screens that need sunglasses to repel,
I left it on the Standard Picture settings to make my personal adjustments
to the picture,I lowered the Backlight a tweak and also the Contrast,Also
reduced the Colour a tiny amount,Sharpness down slightly as well,
But upped the Brightness a touch,Other settings were not altered.
There is no point me telling you the settings I used as this was only a
quick setup,will be doing a more in depth one
When I get time.
I used the THX Test/Setup DVD,As you most likely already know the THX Test
is available on some Film Dvd's.
The Sonys Colours are warm and natural,the best I have seen for a long
while.
No sign of motion blur unlike the Samsung I had previously,No problems with
it on SKY-HD,in fact I switched to
BBC-HD to test the Tennis and ended up watching the whole match,Fantastic
picture on it,
The same can be said for Blue-Ray/PS3 and HD-DVD,No complaints at all.
Freeview tuner seems okay also,obviously some channels are worse than
others with some noise on screen as usual etc.The PS3 style menus icons are a joy to use,its so easy to navigate through the menus with the TV picture showing through in the background.
I can definitely recommend this TV,But go and see it in the showroom
first,As I did.Got lots more playing around with it yet....
