SONY DAVIS10 - Not enough Bass
Hi All,
Have the SONY Davis10 but seem to missing a trick.
Theres just not enough Bass.
Ive tried the auto calibrate and it actually takes the decibels of the bass to -6 or something - I want to increase that but cant seem to find a way!
Ive even tried covering the auto calibration mic up when the bass comes in during set up but this doesnt work.
If I set up manually all I can do is set distances.
Thats about the only way I can see of adjusting.
Ive tried manually turning the treble down and putting bass on max (just adjusting with the remote) but this still doesnt sound right.
Any suggestions - The old Sony system I threw away had bone shaking Bass and thats annoyed me now! :O(
Thanks all
Jamie
Thats all OK but managed to suss the settings over the weekend.Have had to turn bass up to the max to get a decent sound (like a bit of a rumble during movies! Not sure the neighbours do!)
You can change all this is the settings so if anyone else has a problem let me know and Ill guide you through it!
Thanks True Blue...
