Sony BDVE370 Sound Advice?
  • Start date
Deleted member 2457
Hi
My brother in law got one of these boxing day and i had a listen to it yesterday and felt the center speaker could do with turning up a little. Does anyone know on here how to do it? I had a quick look at the manuel but it was for the 370 blu ray player?? - strange.
I am pretty sure looking at the remote you just press the menu and look from there, or the sound mode button?
What do you think here? It needs turning up by about 3db at a guess.
Cheers [Y]
Deleted member 2457
f1only:
Has he done the auto calibration on it?
Yep it is all done and set up
But you can tell by listening to it the center needs turning up a little, My uncle got one too just before xmas and i was with him when he had his demo and could also tell then it would need adjusting.
Deleted member 2457
f1only:
As it has the xross media bar in it, can you not alter the output within the menu system?
I am guessing you can yep but with no manuel and its not mine, i thought a few tips might be handy first
I am sure i will be okay, I used to have a all in one home cinema system and used to do it all the time on that one but i have never played with my current setup on mine, i paid someone to do that
Yep i am gussing that too going in the menu system, look for sound and see what happens then
I will then give my uncle a call and tell him to do the same, i think
Deleted member 2457
Big Chris:
gel:...I had a quick look at the manuel.....
I should definitely make this a New Year's resolution - always check my spelling
