Sony 3D blu ray players
  • Start date
Deleted member 2457
Hi
Have sony got any 3D blu ray players that are compatable with non 3d amps?
If not are they likely to get some soon?
Also i have noticed the current sony 3d glasses are quite expensive like £95 (i think) are there any cheaper ones i could buy that would be compatable with my sony 46hx803 3d tv?
Thanks [Y]
no and no
the only 3d players currently compatable with non 3d avr's are made by panasonic and samsung afaik gel..
and you have to use the same make glasses as your tv too..
Deleted member 2457
Just heard the gadget show is talking about 3d tvs tonight at 8 folks
Deleted member 2457
maxflinn:
no and no
Cheers Max
I am just going to have to wait to they dramatically drop the prices of the current crop then.
Cheers mate.
gel:Just heard the gadget show is talking about 3d tvs tonight at 8 folks
that was last night gel.. it may be on their website though...
sonycentre
50
Hi gel,i have the sony bdpss470 blu-ray player,it does have optical/coax outputs..but you will only get normal dolby digital/dts sound,Save up and get a sony strdh810.i have one and for the money it's a cracking little amp.it all works well with my kdl40hx803/ps3/blu-ray player/xbox 360 elite/toshiba hd-dvd player..and you can use the arc(audio return channel) too.
Deleted member 2457
maxflinn:gel:Just heard the gadget show is talking about 3d tvs tonight at 8 folks
It's on fiver Max i did not watch last night, did you?
Deleted member 2457
sonycentre:Hi gel,i have the sony bdpss470 blu-ray player,it does have optical/coax outputs..but you will only get normal dolby digital/dts sound,Save up and get a sony strdh810.i have one and for the money it's a cracking little amp.it all works well with my kdl40hx803/ps3/blu-ray player/xbox 360 elite/toshiba hd-dvd player..and you can use the arc(audio return channel) too.
I can't get another amp mate, just making enough room for a small 3d blu ray player.
Is there much difference between the 470 and the 570, i think i heard someone say there was not much difference.
Cheers.
gel:
no,i dont have fiver either..
Deleted member 2457
maxflinn:gel:
ah okay mate
Just seen the beginning and they are going to talk about it incase anyone is interested.
daveh75
sonycentre:Save up and get a sony strdh810.i have one and for the money it's a cracking little amp..
Are you seriously suggesting gel should replace his very capable mid-range Pioneer amp with an entry level Sony?
I think going for either the Panasonic or Samsung BDP would be a more sensible suggestion....
Deleted member 2457
daveh75:
Yep the panasonic and samsung are definetely more sensible
i think if i want a sony or pioneer i should just wait to they can do everything.
I can wait, the 3d was just additional bonus for me.
Cheers mate
Deleted member 2457
sonycentre:The bdps570 has built in wireless...thats it.
Ah okay, cheers mate
the 470 makes more sense then, and i think it's lighter. Have you got any plans to release an 3d blu ray players than would work with my amp?
Cheers.
sonycentre
50
Yeah gel..prob next year,sony showcases all its new gear in jan2011.oh and im sorry i did not know you had an amp...and daveh75.there is nothing wrong with sony's strdh810 amp..i did have a onyko 605...and the sony sounds loads smoother.
daveh75
sonycentre:and daveh75.there is nothing wrong with sony's strdh810 amp..Not suggesting there is, it's a cracking amp for the money...But would be step down, compaired to gel's current set-up.
Deleted member 2457
Andrew Everard:
And if you gained any knowledge from that, well done...
No not much, if anything
Okay guys my tv just turned itself off and when into like standby mode, stayed there for about 5 seconds and then turned itself on again. It had been on about 2 hours, i have had it one week and it has never done that before.
Any ideas what that is all about?
Deleted member 2457
sonycentre:Yeah gel..prob next year,sony showcases all its new gear in jan2011.oh and im sorry i did not know you had an amp...and daveh75.there is nothing wrong with sony's strdh810 amp..i did have a onyko 605...and the sony sounds loads smoother.
Okay mate, no probs thought i would ask
Deleted member 2457
Andrew Everard:Gadget Show automatic quality filter...
It was on sky news at the time.
Deleted member 2457
I mean i am not worried or anything just curious why it happened?
gel:Andrew Everard:
gel, did they even compare different models? if so which one did they think was best? from what models? ta..
Deleted member 2457
maxflinn:gel:Andrew Everard:
er, did not compare models or anything, just talked about 3d glasses and what they thought of it and what others thought of it.
Not that much really Max.
My tv just turned itself off and back on again, i have never seen that before
