Solder or screw?
Recently change my speaker cable (Chord) and question whether there is any audible difference between connect via banana plugs with just the screw fitting- or whether I should solder.???
Is there any appreciative difference doing the latter
shafesk
136
I screw but only because I don't want to solder my cables. Mind you, my cables do oxidise after a few months so I have to trim them a little bit. If you can't live with that then bring on the soldering iron! :dance:
idc
1,123
81
19,270
Screw is fine for domestic application swehere the cables will not be moved about. Solder is best for pro audio, especially where the cable will be moved regularly.
Sospri said:
Both, screw and solder, sorted....
+1 on that. If you can do both, why not.
AFAIK, pretty much all internal wiring is soldered, therefore I don't see why speaker cable connections should be any different - where practical.
