Sky Hd remote
Anybody ever have problems with their sky hd remote control? I've changed batteries, held select and red etc, even disconected socket. Nothing - remote not working...
Someone said it may be the reciever of the remote on the box. Manually the box is fine regarding changing ststions. Also, when I save other chanels like bbc hd and itv 1 hd the stations are lost after about a month. All comments welcome.
It could be the infra red bit in the hd box or the remote. I had a creek evo amp where it happened to.
Get in touch with sky directly and they should be able to sort it out quickly for you.
I've had this happen a few times. The usual solution is to remove the batteries and leave them out overnight. When you pop them back in the remote should be working again!
Lets hope the easy solution works, otherwise its a sky callout, and that can be costly!
