fr0g said:
Hallo!
What dm says.
Basically you cannot expect the Pro 50 mk1 to shake the walls. At reasonable levels it goes very low (30Hz), but you can't expect an 8" cone to make your chest squirm.
Don't ever try to guage its level by listening to it alone...Low bass is not as "loud" to the human ear as frequencies in the mid-range.
All the sub should be doing (with music) is giving extra body to the sound.
Also. Put the sub where you sit. Then put the music on...Now walk around the room and see where the bass is deepest...that's where you should put it if possible.
Also, depending on the amp you may need to alter the phase. Usually either 0 or 180 is best, but I have found 90 to be perfect too...depends on amplifier.
Level...For me, never more than 50-60%.
I used both high and low level and found it similar. Best IMO is to use an AV amp with sub connector, set speakers to small and let the AV amp split the signal. This makes the overall sound cleaner.
By the way, I still use mine in my AV system, and it does a pretty good job considering the room size. But again, you aint gonna get REFERENCE levels.
Yes i think i'm finding the sweetspot now. I don't know where the frequencies are on the sub as there are no incremental markings so i've used my ears, think it's around 60hz where the Dalis roll off, how do you work out the frequecy points on the sub? Volume very low, about 30-40% on the sub and now i have extra headroom to turn it up without overloading the woofer. I was playing some dubstep yesterday with Arc 2 and the full range bass correction enabled and i was getting some pretty deep bass at decent levels so it's got some depth if i need it. It's funny you mention 30hz cause i found putting a eq cut around there prevents the the distortion. Also phase at 90 seems to be spot on. The bass aint trouserflapping but it's pretty good considering the size of my room.
@drummerman, i've seen the speakon cable for around £18.99 which aint too bad but what i'm hearing now is much more in line with what i was hoping to attain by adding a sub! The level is a factor though, although i couldn't hear the sub at mid volume it was too loud to allow for much input before overloading and this was while setting up so i thought there was something wrong.
I hope this will help anyone setting up a sub, keep the subs level low if your running into issues, i think midway is a bit too high but perhaps it's different for larger subs? And back off the volume relative to your main output. Regarding cables, what's the minimum amount i should spend? I bought a 10m Fisual cable just for setting up but what i'm hearing sounds pretty good, could it be improved with a y cable?
Anyway thanks again guys for responding. I think i'm cooking with bass now.
