Should I get the FREE upgrade?
I'm buying the Q Acoustics Home Cinema Pack, and due to short supply of the four satalite speakers, the Q Acoustics has offered to upgrade them to the next model up!! Is it as simple as a big fat 'YES PLEASE' or will the change in speakers unsettle the balance of the whole system?
Any advice will be more than welcome,
Thankyou,
Russ
Thankyou Andrew!
Is there anything I would need to set up differently to compensate for the difference?
Russ
Brilliant, just confirmed the upgrade!!
I don't suppose I could trouble you for another quick question?
Could you recommend a stand to hold a LG 42LH5000 tv, the centre speaker from the Q Acoustics Cinema Pack, a PS3 Slim and a Sony STR-DH800?
Should the central speaker be at the listeners ear level? I have stands for the satalites already.
Thankyou again,
Russ
Big Aura
522
10
18,895
ideally so, but practicality generally takes over. I have mine sitting a bit lower, and it doesn't make a lot of difference. Take a look at The Plasma Centre for some storage ideas - find something that suits your budget and decor.
Thankyou Big Aura, I'll check them out. Am SO excited about hooking all of my equipment up!! Haved saved for a long time and can't wait!!
scene
Remember to upload pictures of the finished set up to the "Your system" part of the forum.
I have a note on my PC to do the same, just as soon as I get the cabinet sorted...
Andrew Everard
1,878
RG550:Could you recommend a stand to hold a LG 42LH5000 tv, the centre speaker from the Q Acoustics Cinema Pack, a PS3 Slim and a Sony STR-DH800?
I'd go for an Atacama Equinox AV
Andrew Everard:
I agree. i use the Atacama Equinox AV for my kit and I think they're brilliant!
Brilliant!! Thankyou all very much for your advice and help, have a great weekend!!
Russ
