Here's my setup
Do you think I should fill my stands with atabites?
One point I'd like to make is that the central plugs for the posts are VERY loose, and I reckon they would just fall out.
Also
the plugs for the outer posts are so tight that I reckon if I put them
in I may never get them out (without completely ruining them).
So
what do you think? Are there improvements to be had? I think it might
help as my floor is very un-even and they could do with more weight at
the bottom...
Also how much should I buy if i do?
ta
Also
So
the bottom...
ta
