I have an issue with an amp tripping. Ichange the amp it still trips. I change the speakers, it still trips, i have run another set of speaker cables....you guessed it. It still trips. It trips with the amp not connected to ANY source.I've even run an extension lead to take power from a different circuit in the house (before you ask!) So logically I have not got any problem.... All I have not tried is shielding the speaker cable. The cables run fairly close to the main fuse box for the house and they also run fairly close to other cables, including power cables. So my question is: HOW CAN I SHIELD MY EXISTING CABLES? Is there some sort of copper shielding that Ican buy similar to that found inside coax cable?? And will any such shielding make any difference? many thanks
