A admin_exported New member Aug 10, 2019 2,556 4 0 Visit site Sep 14, 2010 #1 Thinking of buying the C7000, if ant owner's have a tape measure handy could you please measure from the table top stand to the bezel edge/screen edge to see if my centre would fit. Ta
R robjcooper Well-known member Sep 29, 2008 61 0 18,540 Visit site Sep 14, 2010 #2 Will do so for you when I get home tonight ! Rob
R robjcooper Well-known member Sep 29, 2008 61 0 18,540 Visit site Sep 14, 2010 #3 Hi Sammy, from table top to bottom edge of crystal surround - 59 mm from table top to edge of screen - 130 mm Hope that's the info you needed. Cheers Rob
A Anonymous Guest Sep 14, 2010 #4 Thanks for that, going to get a Monitor Audio Radius HD centre which is 125mm so will fit just nicely Thanks again for the help Cheers Sammy
