Hi Everyone,
Recently purchased, the Yamaha RXV 3067, and have a bit of a problem, i have a Sony 40W4500 tv, a Sony BDP 350 Blu Ray player,
Sony RDR HX 900 hard disc recorder, Apple tv2, Sky HD, and an infocus IN72 projector, (B&W MT30 speakers).
The problem is, Ive connected the sky via hdmi to the amp and run a coax cable for sound to the amp AV1 input on amp, (because apparently wont get 5.1 through hdmi cable, is this correct?
Also connected the blu ray via hdmi to the amp and run a coax cable for sound to the amp AV2 input on amp do i need to run the coax to get 5.1 sound through from blu ray?
Ive run the apple tv into AV3 input, havent tried it yet !!
The tv part seems to be working nearly ok although i cant get it to play through without turning the amp on, but i don't watch movies on the tv, as my speakers aren't set up in the right place for it so the centre speaker is at 90 degrees to the tv normally only use surround sound on projector or to listen to music, so i need to be able to watch sky, and dvds, through the tv without switching amp on....how do i do this?
I've got the projector wired up using component cables as 1) this was all my old amp had, 2) the projector only outputs at 561p, it does have an hdmi connector on the back but i cant run a cable to it as room is finished decorated and all wiring is hidden, when i bought the projector hd was only just available so not an option, basically I'm not getting a picture on my screen when i turn the projector on, well i am getting the background picture from the amp and menus up but no piccy from blu ray discs. Any suggestions?
I really would prefer the projector to work with blu ray player, and surround sound, so may have to go about this another way.
Hope this makes some sense
Any suggestions welcome
Thanks in advance
Mull
Thanks in advance
Mull
