landco
Will you be placing small bookshelf speakers on the floor? You say absurd things, my text is for reasonable people 🙄So a standmount speaker will sound just as good placed on the floor as it does on a stand? Rubbish.
I think it's just the way he worded it Doug.So a standmount speaker will sound just as good placed on the floor as it does on a stand? Rubbish.
See my post #27 for an explanation as to how 'reasonable people' could misinterpret what you said.....thanks to your ambiguous wording 🤨Will you be placing small bookshelf speakers on the floor? You say absurd things, my text is for reasonable people 🙄
Generally, speakers are optimised to work at their best with the tweeter about ear height, regardless of floorstanders or standmounts. Of course there are a few exceptions.The absence or presence of stands does not directly affect the sound, the location of the speakers relative to each other is important (affects the stereo base), the distance to the listener and the width of the speaker radiation (high-frequency and mid-frequency spectrum)
I listened to a pair of Spendor A2 floorstanders in my local HIFI shop ages ago and they are so tiny. To have their tweeters at ear height, you'd need to sit on the floor. They cost a fortune and I'm not joking, they need stands!Generally, speakers are optimised to work at their best with the tweeter about ear height, regardless of floorstanders or standmounts. Of course there are a few exceptions.
Yes, they’re quite unusual in their stature, but designed to work in smaller rooms according to Philip Swift, Spendor’s MD.I listened to a pair of Spendor A2 floorstanders in my local HIFI shop ages ago and they are so tiny. To have their tweeters at ear height, you'd need to sit on the floor. They cost a fortune and I'm not joking, they need stands!
Ideally suited for a doll's house 🙂Even tinier, but designed to project upwards, I’ve always thought the Neat Iota Alpha was great fun.
As I said there are a few exceptions where they are designed to work higher or lower. And some are designed to work in the retail business, such as restaurants, pubs and other outlets. Alan Shaw, owner of Harbeth, points this out in one of his videos.I listened to a pair of Spendor A2 floorstanders in my local HIFI shop ages ago and they are so tiny. To have their tweeters at ear height, you'd need to sit on the floor. They cost a fortune and I'm not joking, they need stands!
Is that why Cindy has a smile on her face?😁Ideally suited for a doll's house 🙂
I only went for the baby Harb's as I'm a vocals person and every review I read said they were particularly sweet sounding in this respect. An added bonus was they completely eradicated a bass-boom problem I had with every other speaker due to placement issues. My room is 4x3.5m and I sit hard against the short side rear wall, the speakers are 21" in from side wall and 12" in from front wall, both measured to tweeter centre. The placement actually adds a bit of heft to the bass... they're not bass monsters by any stretch, but enough for me.The new QA5040 get good reviews. I'm going to try and listen to a pair and see if they have that top end sparkle I'm missing with the QA3030i. The footprint seems to be about the same.
There's lots of Spendor, ProAc, Harbeth and ATC mentioned in these speaker discussions, but no mention of QA.
Are people dismissive of this brand, because they don't have that really high price tag?
I don't think QA have made a bad speaker, since the brand appeared ages ago.
Replace the spike shoe pads with circular wood cut outs, these are much safer, less fiddly and costs pennies.Yes I can and sometimes do when "The Boss" goes to bed .... it does alleviate a large amount of the issue but they're on spikes which makes it a pain to move and have just bought cups due to the massive number of holes they're leaving in the laminate (looks like I've severe woodworm) but they make it more of a hassle.
To answer the question, yes I can but it's a PITA .... was thinking about try to put wheels on something to make it easier.
....as it should to everyone really, due to the implication for the overall sound.Accuracy of vocal reproduction does appeal to me,
A speaker is only as good as the amplification and vice versa. In other words both components are reliant on each other.Accuracy of vocal reproduction does appeal to me, but it's a lot of money, even with the cheapest Harbeths.
I know I'm always going to sacrifice a bit of this with a cheaper speaker.
I'm hoping the QAs give me more 'air' with the type of music I listen to. My fear of floorstanders, is that bass integration, although the QA5040 are tighter in the bass than previous models, according to the reviews and I can always shove the foam bungs in.
You don't need wheels, with these underneath, the speakers just slide on laminated floors.
I can't recall the amount of times, I stabbed my finger trying to put the spike into the hole, you put one in and another moves out of place aaaghh! These are a doodle and they do look nice
They sell them everywhere eBay, Amazon, Etsy etc.
Harb's definitely aren't for everyone. It's always what sounds best to your ears, works best in your room and fits your budget. Such a lot of trial and error, I do not envy you and wishing you the best of luck 👍Accuracy of vocal reproduction does appeal to me, but it's a lot of money, even with the cheapest Harbeths.
Sounds like a good case for active speakers.A speaker is only as good as the amplification and vice versa. In other words both components are reliant on each other.
I have internet problems here in the Welsh Valley where I reside and I was merely going to complement those lovely looking speakers at the front. Are they the ATCs? In addition I felt a little stupid not knowing which they were so I bottled out of replying. 🥴@JDL did we lose your reply?
