I would like to buy new interconnects between my Roksan Caspian CD and Caspian integrated.
Has anybody tried Roksan HDC-02a interconnects and what are impressions?
atinka1 said:would like to try Roksan HDC for two reasons:
Because that is mentioned in user manual and because people from Roksan recommended those
when i contacted them recently. They said that their ICs are completely in synergy with Kandy and Caspian components.
atinka1 said:something is telling me to try those made by Roksan because i am asking myself why did they constructed it, despite the fact
that there are a piles of good cables at the market nowadays if they do not really think that they are good.
Usman24 said:Just buy a set of these:
http://www.futureshop.co.uk/van-den-hul-the-d102-mkiii-stereo-audio-cable-10m-p-639.html [brilliant ic's. Clean, clear, detailed sound with excellent bass] a classic VDH cable. No need to spend more as I have demoed many, many ic's in my system and these are on eof the best at any price.
Obviously you should search online for the best price and make they are original VDH cables. Good Luck
MajorFubar said:Roksan's own cables are probably very good, but if you really can't work out why they are telling you to use their own-brand cables to get the best results, then you must have just crawled out from under a gooseberry bush.atinka1 said:something is telling me to try those made by Roksan because i am asking myself why did they constructed it, despite the fact
