Replacing Musical Fidelity B1
Steffan777
Hi Folks
My wanderful Musical Fidelity B1 amp is playing-up so I sadly have to replace it.
I'm running a 25 year old set-up inc. Marantz CD60SE and Roger's LS6a speakers. With the B1 the set-up sounded great, really nice an warm!
I think the B1 was £200, the CD £250 (ish) and the speakers £350 (ish) in 1990 (ish) £££'s.
I'd be interested to hear your views on roughly how much I should be spending in todays £££'s to replace the B1 with possible small upgrade in sound quality?
Maybe it would be easy (ie - I should be asking) about the cost of equivalent standard equipment in todays money.
Depending on the response, I suppose I might have to spend a bit more on replacing the whole set-up! :)
Many thanks in anticipation
wondered if anyone could give
gregvet
128
10
18,595
I haven't heard any of the equipment in your setup so can only talk in general terms.
I think you are going to be looking at significantly more than £200 to get the same/better sound quality.
A good starting point may be the Rega Brio, approx £450, as it is musical and a nice all rounder.
Would you consider second hand?
Infiniteloop
51
6
I used to have a Musical Fidelity A1 Amp about a hundred years ago and loved the warm, approachable sound. - It's what got me into Valve Amps.
I suspect the B1 has a similar sonic signature to the A1, so maybe this is a route you might want to investigate?
