Remote control cable?
Hi.
I've just purchased an Onkyo HTX22HD. It's working a treat but the only problem I have is because of where the amp is located, it's not always receiving the signals I send from the remote.
The back of the amp has a socket labelled "remote control", so I'm assuming I can put a cable in here and postion the IR sensor for the amp somewhere suitable.
The question is, what cable do I buy and where from?
Keene.co.uk sell a range of IR kits and if it has a 3.5mm jack plug, those should do. I use a few of the products myself to control equipment inside a wardrobe.
http://www.keene.co.uk/multi.php?mycode=IRSR
Double check that it is suitable though.
