Al ears
I quite like 'different '......An acquired taste in every respect (even the 'Einklang' model name 🤪)
I was referring to the sound of the products. Clearly it’s not fair to criticise a review because they didn’t predict that my copy would break. I believe it is very hard to predict longevity.
Unfortunately most reviews use terms that to me are meaningless: rich, warm, dry, authoritative, sweet, articulate and so on. I can understand what is meant by an exaggerated treble, or a lack of bass. My Arcam Solo Movie was described in some reviews as having a rich, warm sound, whatever that means. Mine has a muddy sound, with a reduced treble, and little soundstage.
At least when there are measurements, you have something that is not totally subjective.
As a reviewer, you have to describe the sound of that product - just saying it’s got a bit less treble than average or more bass than usual isn’t enough. They have to get creative.
I can only mention some things I came across. I think it is fairly difficult to predict shelf life but with additions like gels I am quite sceptical and those are usually a dealbreaker for me personally.
I barely see anything about this topic in reviews. I also doubt if anyone would give it a shot as consistancy is key, so technically opening up all models is required for a full analysis and this could harm sales.
B&W seems to have used some gel around some of its tweeters in their late 90s / early 2000s and some speakers in general had elastic elements that turn brittle over time.
A company like Q-Accoustics uses a trademarked "gelcore" and I don't have any idea about how much time it can handle, but it is not what I would buy as a product for life..
There's a risk of degradation with many materials, not least capacitors used in loudspeaker crossovers. It's highly unlikely that modern speakers will fail early as long as they are used with respect.
The 3000i (and I believe new 5000) series Q Acoustics speakers don't use the gel core construction, but even so it wouldn't put me off a pair of Concept series. The speakers are so good, and I trust the Q team to get things as right as possible.
Everything has a finite lifespan - look at the ferro-fluid tweeters used in some older designs, and the foam surrounds on many speakers including Heybrooks. It's just a matter of course.
I can't think of many components that didn't have a weak point somewhere, even from established brands. The volume/balance control on the Pioneer A400, switches on the later Arcam Alpha amps, wall wart PSUs that start buzzing like mad on Rega turntables...
There are some great brands that are built like should last for ever as they are indefinitely repairable e.g. Linn turntables. I bought my Axis from a friend back in 1998. He bought it in 1989. I had to have the board rebuilt with new capacitors a few years back but that's it. Its one of those things that if it goes wrong it can be repaired. If it was an LP12 it could be rebuilt with so many upgraded parts it would be the ultimate 'Trigger's Broom'!!!
I'm hoping my Dalis last as long as my Tannoys as that should see me into my 80's. Amp and CD, not so sure, but like anything if its looked after it lasts longer.
Reliable multipurpose electronics are a Japanese specialty. I considered buying the Arcam Solo Music on deep discount 4 years ago but just couldn't ignore the "too good to be true" factor.
I would hope that as part of Harman Luxury Audio (and thus Samsung), Arcam could now be much more price efficient for customers given the scale of the company's resources.
And you've just bought a new battery for it 🙁today I confirmed that the Chord Mojo is at fault, the micro USB input is not working.
I'd say his expectation is too low (although perhaps increasingly more realistic these days).
I expect (and so far have had) well over 8 years from everything I've bought.
My old amp was (is) 20 years old - It looks, operates and sounds as it did on day 1.
Got to be honest though - I wouldn't bet any money on the new amp lasting half as long - although, for its price, it bloody well needs to 🤨
The capacitor problem is a particularly painful one. Capacitors should be chosen with good safety margin with regards to voltage rating. This a problem for electrolytics since most MKT, MKP etc caps have naturally very large voltage ratings. The next best thing is to upgrade any 85C ones with 105C ones.Amps fail prematurely because they’re not given sufficient ventilation, meaning they run at a higher temperature than they’re designed to. Others, the capacitors fail as the amp is used with a speaker that is too demanding for its capabilities. And abuse, of course. There are still those that think that a volume control can be turned all the way up to obtain an amplifier’s full power.
Yes my Teac separates lasted 15 years before I sold them.
My belief is that a lot of products today (last 5-10 years) aren’t made to last. I’ve had an expensive frying pan warp, replaced under warranty only to warp again, a very cheap Tesco pan lasted over ten years until I abused it. I have had kitchen items with plastic that becomes sticky after a few years and I had to throw them away. I’ve already mentioned I went through three Apple watches, and two Withings watches, made using glue rather than properly put together unlike real watches. Globalisation increasing competition, making it harder to survive, with an emphasis on social media influencers and magazine reviews perhaps? I could be totally wrong.
