Rega BrioR with ProAc 115-series?
Concertino
Hi all!
I would love to try out "UK speakers" on my BrioR/DAC.
I am now using Sonus Faber Concertino Domus and it sounds wonderful. But still, i miss some exitement as these speakers are kind of very warm and romantic. On the other side there are no unpleasant S`s or shrills and it`s important for me to avoid speakers that are to thin/lean/sharp/bright sounding.
I am considering Rega RS, Neat Motive, Tannoy DC Sign. and maybe Spendor(if i can afford them)
I would forget the Spendor - the Brio R isn't going to have enough poke to get the best out of them, but do try them if you're curious. The Studio 115's sound great on them, and they match up pretty well, but I wouldn't expect club levels from them. The Neats should be ok, but that's not a combination I've tried as yet.
Concertino said:
Hi all!
Hi concertino
I've found Monitor Audio's superb new GX50's and GX100's to work a treat with Rega's Brio R and DAC 🙂 Btw, Dynaudio's Excite X12's are also worth a look.
All the best
Rick @ Musicraft
Thanks a lot for advice! The Spendors are not cheap over here so not my first choice anyway.Heard some rumours that Neat Motive could "bottom out"(?) and sometimes be a tad to bright as well. Looks like the ProAc`s could be my speaker. I don`t need club level at the moment. Living in an old classic building, most of my listening are done beyond 10 on pot. But my six year old has started to show interest so... :dance:
[/quote]
Hi concertino
All the best
Rick @ Musicraft
[/quote]
Hi Rick and thanks!
Yes, MA could be worth an audit as well 🙂 I will gooogle them.
Dynaudio: Actually, I am a fan of Dynaudio in general. Great speakers! I owned the A10 back in the 90`s.
But not this time(i think) And I would prefer a front,side, or bottom ported speaker because i need them to be pretty close to the wall without coloring the sound to much.
BR,
Erik
Hi concertino
All the best
Rick @ Musicraft
[/quote]
Hi Rick and thanks!
BR,
Erik
[/quote]
Regas own RSs are a corking match (so I've been told), and also consider PMC.
Thanks!
Problem; Can`t get hold of them for an audit here in Oslo🙁
AND, not sure if i like their looks.. but it`s Rega, and not very high £ either🙂
BR,
Erik
MUSICRAFT said:
Concertino said:
Hi all!
Hi concertino
All the best
Rick @ Musicraft
+1 Dynaudio Excite X12's are the best speakers i have heard with the rega brio R
THESTIG08 said:
MUSICRAFT said:
Concertino said:
Hi all!
Hi concertino
All the best
Rick @ Musicraft
Hi THESTIG08
Yes, the Brio R and Excite X12 combination also works a treat 🙂
All the best
Rick @ Musicraft
