Lateste upgrade a Rotel A11 tribute.
In another amp matching thread somone metioned the Rega brio R might work better with the slight brightness of the B&Ws. (i remember someone saying the rega brio r is a little bright)
I have a pair of B&W 607 s1 and they sound good, going from a big class d amp and a nad preamp to a Rotel A11 Tribute give me a wider soundstage and more depth + a little better midrange but also a little more brightness and less bass,warmth , as soon as i play something with bass theres bass and playing something really good recorded theres not much brightness, could be paul simon's Still crazy after all these years.
Can't help thinking i need a little more bass and less brightness on some song and it's not just using the tone controls since i think theres often something wrong with a systemn if you need to use tone controls, eq unless it's because your getting old and can't hear the highs so good anymore
Rega brio R vs Rotel A11 tribute which one is better ?
Measurements and commets on the highs of the B&W 606 s1 https://www.soundstagenetwork.com/i...&catid=77:loudspeaker-measurements&Itemid=153
