Rega Brio R amp speaker cables
Svaja
I'm just trying to set up my new system, but I'm confused about what speaker cable to use between my Rega brio R amp and Wharfedale speakers.
Do I need a cable with banana plugs for the amp to plug in or can I just twist a plain wire around the fitting. I can't find any info on this anywhere atall.
Thanks!
ISAC69
73
The Chord Carnival SilverScreen speaker cables can be a good option for you .
You can use banana plugs or just twist a plain wire around the fitting but it is better to use banana plugs .
