Question Rega arm won’t level after a rewire
PBo13
Hi all,
After clumsily ripping a cartridge tag off and rewiring the arm on my RI can’t get it to float. With counterweight pushed fully on, its already too heavy, lifting the head.
I’ve checked if the deck is level, and made sure everything was reassembled ok.
Any ideas?
thanks
Al ears
Moderator
That should say RP3...
Am I missing something here, to balance the tonearm you have to move counterweight backwards.
Apologies, just read that again and see what you mean. Have you refitted a cartridge yet?
Is that arm rewire pulled really tight? It shouldn't be.
For what it's worth the tonearm is the RB303
PBo13
The problem is the arm is already tilting to the counterweight end before the counterweight is moved away - it’s as close to the pivot as it can be... as if the arm isn’t heavy enough. The cartridge is pretty close to the end.
I’ve just realised something. The arm had a plug in the end near the tags. I wasn’t able to replace it. I bet that’s what’s causing the issue. I need to make the headshell end heavier...
Al ears
Moderator
That's probably it. The weight of that plug has to be taken into account. Just a thought, do Rega do a lighter counterweight. I know they do heavier ones.
There's always the option to replace the cartridge with a much heavier one..... :)
ASK THE COMMUNITY
