I need to add storage according to my blu-ray player in order to play BD live content it has no internal storage but it dos have a USB port. So what size USB stick would be the best size?
lordy said:Philiptech,
1mb or more is what you need (as above) but would you not be better off using an SD/SDHC card; much more compact and out of the way than a USB stick projecting out of your player.
bigboss said:lordy said:Philiptech,
....only if the OP's player has an SD card slot (I'm not sure if it'll work even then).
