- Aug 10, 2019
- 2,556
- 5
- 0
Hello allI'm thinking of sorting out my various video/hi-fi requirements and am looking for either a receiver to which I can add a blu-ray and surround speakers later, or an all-in-one home theatre surround system to which I can hook up other equipment:
XBox 360 via HDMI or component + optical
Apple TV via HDMI or component + optical
Sony DVD player - now this is a 5.1 system with no HDMI or optical out (it does have optical in, however)
BT set-top box/PVR via HDMI
All this is currently playing on a Sony 32" HD TV. The AppleTV is using the DVD's optical input which I occasionally swap for XBox or Freeview. The TV has no optical connection.
Music is streamed from a Mac to my Apple TV so there's no CD player. And most of my video is actually handled in the same way - I rarely play DVDs now so the DVD player is effectively just a receiver. It's the lack of connectivity and scalability which is making me look at updating.
So... here's what I'm thinking, bearing in mind two things: my budget is not great (say £600 max at the moment) and I live in a small-ish flat in a quiet neighbourhood so I'm not looking for power, but for something that gives good quality at non-neighbour annoying volumes.
A receiver with two HDMIs and two optical in, with optical out so I can plug it in to my Sony DVD player for 5.1 surround. At a later date I'll add 5.1 to the receiver directly and pension off the DVD player, replacing it with a blu-ray unit.
Or
A home theatre system with blu-ray and 5.1 with speakers, but which has two HDMIs, component and (possibly) optical in
In the former category I can find likely candidates but without optical out. Which is no good.
In the latter category I can see plenty of good-looking blu-ray home theatres but without HDMI in
Any pointers to suitable options or general advice appreciated. Thanks!
Or
