Please refer to the previous post!I would like to know what he has done too !
I dare say that many more people would hear your violin tweaks than would hear any cable swap Andy.I’m a professional violinist, my violin is only £5000, I frequently tweak with strings and bridge, and bow.
Optical sounds better for than RCA .
YES Optical is better using a PM7000n and a CD60. Sounds much better too me.Optical is better for CD60 into the PM7000n than RCA? Is this what you are saying? Are you thus using the PM7000n DAC?
Please clarify what you mean.
did yiu seeNeed to get a CD6007 or CD60 first! It's on my list for next paycheck.
did you see the deal on Amazon that some 1 posted ?Need to get a CD6007 or CD60 first! It's on my list for next paycheck.
Congrats 👍So you prefer the DAC in the PM7000 over that in the CD60.YES Optical is better using a PM7000n and a CD60. Sounds much better too me.
You do know that this is a really a DAC comparison and not really a cable comparison?YES Optical is better using a PM7000n and a CD60. Sounds much better too me.
Im learning 🙈👍You do know that this is a really a DAC comparison and not really a cable comparison?
If you're just comparing cables, stick to the same type of cables with the same sources and amps. While we're at it, I've just upgraded from Chord C-line interconnects to Chord Clearway. Pretty noticeable difference - more focus, better leading edge to notes. I really think some of you non-believers should give it a go, just saying.
I'm not about to turn yet another thread into a "cable debate", you are more than entitled to your beliefs and opinions and if they float your boat then good for you.If you're just comparing cables, stick to the same type of cables with the same sources and amps. While we're at it, I've just upgraded from Chord C-line interconnects to Chord Clearway. Pretty noticeable difference - more focus, better leading edge to notes. I really think some of you non-believers should give it a go, just saying.
I really think some of younon-believersobjectivists should give it a go, just saying.
Hey touche my man!! 😆 😆Fixed it for you. Objectivity isn't a belief system.
Conversely, maybe some of you 'believers' should give double blind testing a go, just saying.
Interesting you've brought that up I was trying to work it out the other day. I think it's about £320, which I admit is quite a lot when my hardware costs south of £2k. As you know, I have tried some "kit" changes as you put it, Arcam and Naim amp try outs plus a couple of speaker trials around the £1k area, but nothing has really floated my boat. So it's really been a case of fine-tuning what I've got.Edit: Your cable spend over time must be approaching the cost of your kit... it would be like me spending £12K on cables... never gonna happen!
Interesting side note on the "objectivist" thing. Hi-res objectively contains a lot more data than FLAC or much more than the compressed hi-res I listen to over bluetooth Ldac. Yet I can't hear any difference between the two. Those that can hear the difference therefore have "objectivity" to back up the differences that they hear. Yet I think the vast majority of people with sound but average hearing would not be able to say which is true high resolution. 🤔Fixed it for you. Objectivity isn't a belief system.
