Topping E30 DAC - or something else?
Entrigo
Looking for a cheapish decent DAC to use to connect my Macbook Air or iPhone to my all analogue amp so I can hopefully stream Apple Music lossleess.
Already have a Wiim Pro Plus as streamer and a Marantz SACD8005 on the way (I can use the latter DAC from my iPhone but not Mac) so don't want to spend too much on this. There's a couple of Topping E30 selling for around £70/80 - are they good or should I look at something else?
BTW - Not very clued up about digital music, DACs etc, don't have any hi-res, DSD PCM (whatever they might be) files and would only be using it for Apple Music...
It´s transparant, it will have no negative influence in your chain.
If it has the features you need, go for it.
Was just reading about QC issues and a few of them failing...
And now wondering if I should just shell out for a better one and run my Wiim through it as well.
Is there an analogue output from the latest MacBooks? I'm typing this on a 2022 MacBook Pro model but I only have a printer and the mains adapter plugged in.
I'm thinking I used to run a stereo 3.5mm jack plug to 2xphonos into my system many years ago, from an earlier MacBook. And today, the USB converter I connect the laser printer with would presumably work with a Dragonfly, for example?
I have a Topping EX5 going on 4 years and it has been trouble free.
Excellent headphone amp as well (the reason I still have it as I actually do not need a separate DAC).
Reactions: Entrigo
Yes, at the moment I am connecting it to my amp from the headphone out but someone somewhere suggested an external DAC instead of the Apple one would sound better.
I mean - it's the age old issue: it sounds good enough to me that way but then so did my Wharfedale Diamond speakers 3 years ago until I heard the Focal and realised what I was missing out on. Or using a Google Chromecast Audio as streamer until I heard the Wiim...
The Air only has a USB C but easy enough to get an adapter - that was the plan. And actually yeah I did look at Dragonquest in the past... Although attaching it to an adapter makes it less neat - hence I was thinking about a desktop one connected with a USB C to B cable.
Reactions: nopiano
The Topping E30 is a good choice, I believe the SMSL SU1 for a similar price is even better.
If you can spread your budget a little further.
FiiO's K11 with better construction and sound quality is worth considering.
The non R2R version I've seen on AliExpress for £115 and R2R about £130.
Also it also comes with a headphone socket and wide array of connector options.
Reactions: Entrigo
Oh, I see, then you’ve obviously considered the options. I remember hearing an early Dragonfly connected to a hugely expensive Hifi, and it sounded glorious, just wired to a MacBook of the day! When I see used ones for fifty quid or less I sometimes think “I must try one”!
Reactions: Entrigo
Well got the Topping for £50 on eBay in the end. Pretty inexpensive "gamble".
What Dragonquest did you try?
Reactions: nopiano
Sorry for the philistine question but what's R2R and how does it work /affect playback etc?
Not at all 😊
R2R or Ladder are an array of voltages that function like 010101....etc. takes a different approach to mainstream DACs that are based on chipsets.
Below I had to plagiarised the exact definition from Wikipedia
An R–2R ladder configuration is a simple and inexpensive way to perform digital-to-analog conversion (DAC), using repetitive arrangements of precise resistor networks in a ladder-like configuration
I hope this helps 😉
I’ve never owned one, but the one I heard was either the original or the second generation model. They’ve expanded the range since then.
The Topping is well thought of, so here’s hoping!
BTW, a cautionary tale here, so take care of your speakers!
