axman:Childs1962:
4biddenplanet:Does any one know of a provable, technical reason why one functioning HDMI would be 'better' than another?
The only variable is HDMI versions, v1.2, v1.3 etc, though this is down to functionallity not quality.
Digital either works or it doesnt hence you can take a digital image, audio or video file and drag and drop it on to a DVD-R, take the DVD-R to another PC and drop it on to the hard drive and then copy it to a memory stick, take that to another PC and transfer it via USB cable to a networked drive, pick it up of the network and upload the file to an FTP server, someone else can then download it from the FTP server and it will still be exactly the same as it started.
Analogue interconnects make a real difference, digital interconnects just have to work.
Ok.. appreciate you are trying to make me save some ££, but is there a difference when it comes to real time digital streaming though? Sorry I am not well versed in how digital files are set up. For some reason I am thinking about a salami sausage. If I pass around a whole salami sausage to a few people the last person will have the same sausage. But if I slice it up and pass it around slice by slice, how am I going to be sure that the last person will have the exact same sausage?
Not the best analogy though I will stick with it ;-)
So you slice the sausage and hand the slices over one by one, and the other person reassembles the sausage, if one slice does not fit then it is not the same sausage and will be rejected.
As I say not the best analogy.
I would not skimp on quality in respect of the contruction though I really think that a well made £15 HDMI cable is just as good as a £100 HDMI cable and that any perceived differences are psycological, i.e it costs more so it must be better.
I repeat, analogue is a whole different matter ...
