Q-AV and speaker cables
oxrob
I've seen the Q-AV 5.1 speaker set up bundled with a 606, HDMI, sub cable & Micro Speaker Cables.
I was planning on getting the Q-AV, but have had normal speaker cable installed, not micro. Is that going to be a problem, or am I being thrown by product decriptions and there is really no difference??
Also, I am planning on getting the Sony KDL40W4500, Sony STR-DA2400ES & Sony BDPS550. The Amp & BD player as I remember that using the same manufacturer is a good thing, where possible. And seeing as it is the best TV, 3rd best amp and 2nd best BD at my price range is going all Sony worth the fact that it is not the top kit at the price?
Will all be with a V+ Box for TV...
Thanks,
Rob
Hi Rob,
You won't have a problem with the speaker cable. ÿThe micro speaker cables are included in the package as they're easier to hide if you're not putting cables through walls.
Using products from the same manufacturer is always a good thing. ÿYou've definitely got a good setup going if you opt for all the Sonys mentioned.ÿ
