Q Acoustics 3020 question
starkiller
14
Just got a pair of these and am very impressed and was wondering what power taps do folks use for these? Since they are 6 Ohm and my amp has taps for 4 Ohm and 8 ohm. I have them on the 8ohm tap but was curious if the 4ohm would be better. Because of the way the system is set up i really dont want to change to the 4ohm if i dont have to as its a PITA to get to all the wiring 🙂
Thanks!
If you can feel the 4 ohm taps produce less heat from the amp when playing loud, use those.
