psx-r or cyrus 6 power amp?
I have four hundred pounds to spend and was thinking of upgradeing my cyrus 8 (70 watts) amp, i have the 8 hooked up to a mf x-ray and a pair of b&w cm2 speakers. I was thinking of adding the cyrus 6 power amp (50 watts) and useing it to drive the tweeters while the 8 takes care of the bottom end or just add the psx-r? Does anyone know what would give the most gain? advice needed......
I suspect it depends in part to the speakers you're driving...but I'd probably put my money on the 6 power.
Thanks for the reply, Its a difficult one to call really as i dont know what the psx-r would actullay do to the sound, i think the power amp might be the best bet. cheers..
