I have the been using the above turntable -- Ortofon OM 5E moving magnet cartridge -- for a few years in conjunction with a Marantz PM-44SE amplifier. I was unable to use the phono stage of this amp. as the built-in pre-amp of the Pro-ject caused extreme distortion whentrying to play vinyl. I overcame the issue by using the "tuner" input but annoyingly I have the same problem again after an upgrade !! I have just purchased a new Marantz PM6003 amplifier. This amp. came highly recommended for a budget set-up -- it is coupled with the Marantz CD6003 CD player & a pair of Wharfedale Diamond 10.1 speakers -- as like the PM-44SE it had a MM input so I thought I could use the tuner input again. I have earthed the turntable as per the set-up instructions of the PM6003 but despite trying every input this distortion issue will not go away. After spending good money on a major upgrade to say I am disappointed & worried is an understatement. I have no doubt that the pre-amp is more than likely the problem. Has anyone come across this issue before & if so perhaps be able to offer a solution ? I would be extremely grateful !
Thanks in anticipation.
KKAVFC
KKAVFC
