Primare Remote
John Duncan
2,033
27
19,720
I just got a C31 Remote, but 'Stop' doesn't work on my D20. Anybody else find this? It's obviously sending a signal since holding it down opens the drawer........
It works on the cheap plastic remote that came with the player..........
my posh remote sometimes changes the function setting on my pre-amp when adjusting the volume,it changes back though and dosn't stop anything playing as it should .I don't like it though.
serves me right for wasting £150 on a remote when I already had 2 that were free.
Andy Clough
776
I have the same remote and find sometimes you have to press the 'code' button at the top to change the way it operates. If the green light is flashing (rather than static or off) then it works properly. The left/right buttons should change the input on the amp, the up/down ones the volume. Not sure why stop isn't working.
John I use the C22 remote with the cd/pre........no problems here..........maybe consider switching if u can't sort out the C31?
Clare Newsome
1,657
Ah yes. No pain, no gain
