Thompsonuxb
- Feb 19, 2012
- 125
- 0
- 0
drummerman said:Thompsonuxb said:drummerman said:Thompsonuxb said:MajorFubar said:Thompsonuxb said:?
Then that makes it a glorified mains cable.....
If your definition of 'a glorified mains cable' is a hulking great 500VA outboard power supply that replaces the one in the amp and allows the amp to deliver over 25% more power and over 30% more current, then by your definition (which no one else agrees with), it's a glorified mains cable. Let us know when you find a mains cable that does the same. We'll be all over it.
And there is my point Major.....
The PSX delivers power from the mains to the standard amp the mains chord is replaced by it.
Refer to my previous entrys......
Point I'm trying to make is why some are so dismissive about power chords.
Cyrus's example shows they utilise the mains into their kit to bring improvements so why can't boutique power chord manufacturers do the same - not as extravagantly, but hey.
This is not exclusively about Cyrus..... Let's be clear.
No. The amplifier retains its mains connection as does the PSX. They work independantly, splitting the PSU duties.
So both are connected to the mains?
Yes.
The PSX is connected to it's counterpart via a proprietary umbilical cord.
So the PSU in the main amp still drives the main amp but fully supplies the main unit while the PSX drives the pre amp.....they double usable power.
So for example if the main amp say has a 300watt operating power consumption with the PSX added it could be boosted to 600watts?
