nopiano said:The sometimes pilloried Russ Andrews used to demo his cheapest "yello" mains cable at hifi shows, using a ghetto blaster. It was quite obviously better with his cable rather than the stock one. I've no idea if it was trickery that escaped me, but it was clear enough to everyone there.
I've recently been re-reading some of his articles about room and speakers setup, which make a lot of sense. I actually think he has a lot of knowledge, but I'm well aware how much cable threads degenerate.
Hi,ellisdj said:You have to try a few to make sure you cover all the bases. Maybe the ones tested were no better than cheap ones dressed up so thats why you heard no difference. However maybe others are not. For that reason it makes sense to try out a few to make sure. Now days this is very easy and there abundance of ones to try - but trying 2 different manufacturers £100 models is not the same as ine manufacturers £100 and £1000 models being tested.
The other thing needed to be done for sure is wire the whole system up with said cabling and try that. Thats a proper can I hear a difference test
ellisdj said:Out of curiosity how many people have their full system all wired up with cable from one range from a manufacturer???
I have never done that. I have all my cables power inc from one manufacturer (not all same range) but even then I have other diy and other cables in there.
ellisdj said:I have never said all cables make a difference compared to cheaper ones I just know some i have tested have done. The ones that have made the most obvious difference have not all been expensive but some of the expensive ones have done as well. They have been quite dramatic hence the suggestion to at least try them if you are doing can I hear a difference test. If your not because science says they cant then fair play.
Andrewjvt said:ellisdj said:Out of curiosity how many people have their full system all wired up with cable from one range from a manufacturer???
Both my amps ive used
My hegel and also benchmark
ive, out of interest spoken to both and asked the question.
Would an aftermarket power cable improve the performance of my system?
Hegels responce was no the power cable we provide is more than good enough(and in most cases much better than aftermarket)
Benchmark - i spoke to in person and they laughed when i brought up the subject. Also said there is absolutely no gains to be made.
davidf said:What Ellis is trying to say is that some cables have been produced using genuine knowledge/research, whereas there are some some out there that are literally 'hi-fi jewellery'.
Andrewjvt said:davidf said:What Ellis is trying to say is that some cables have been produced using genuine knowledge/research, whereas there are some some out there that are literally 'hi-fi jewellery'.
Where is the knowledge/research/design that can take power from a wall socket to an amp and improve the performance?
Vladimir said:ellisdj said:Andrewjvt said:ellisdj said:Out of curiosity how many people have their full system all wired up with cable from one range from a manufacturer???
Both my amps ive used My hegel and also benchmark ive, out of interest spoken to both and asked the question.
Contact Wilson Audio and ask them what they think?
I did, last night at 3 am.
I said listen David, I need to know this once and for all, do cables make a difference. He said Yes Vlad, yes. They do. If it werent for audio cables his speakers would sound like 80's Aiwa car audio, because speakers don't really sound different from eachother unless you invest in quality cables with proper scientific research behind them. What's inside drivers Vlad? Wire. What's inside amps? Tonearms, cartridges... Wire! It's all wire.
I finally went to sleep.
ellisdj said:Vladimir said:ellisdj said:Andrewjvt said:ellisdj said:Out of curiosity how many people have their full system all wired up with cable from one range from a manufacturer???
Wilson Audio apparently do listening tests on the solder they use and now use Transparent Opus cable in their speakers. I dont think after 30 years tons of awards and a heritage like they have they need anything that small to boost their sales
Hi,ellisdj said:Vladimir said:ellisdj said:Andrewjvt said:ellisdj said:Out of curiosity how many people have their full system all wired up with cable from one range from a manufacturer???
You'd have to ask the manufacturer that.Andrewjvt said:davidf said:What Ellis is trying to say is that some cables have been produced using genuine knowledge/research, whereas there are some some out there that are literally 'hi-fi jewellery'.
ellisdj said:Be honest if you could pick what would you have???
lpv said:ergo: wilson audio is high end, benchmark, hegel & bryston are ****... cause they all dismiss importance of cables
ellis: just an idea, maybe wilson audio want to sell more cables for transparent opus? maybe they have deal? or transparent are so reach now they don't care about sales anymore?
Vladimir said:ellisdj said:Be honest if you could pick what would you have???
Give me that musical solder!
