- Sep 25, 2008
- 7
- 0
- 0
Hi guys, first post on here, been lurking in the shadows for a while. (the forums helped me choose my receiver and speakers just over a year ago)
I have the chance of getting hold of the above mentioned set as part of a competition. Its not a certainty yet but ill be mightily dissapointed if someone beats me at this stage.(2nd prize is 42G10)
I was wondering if anyone has first hand experience of the set? I'll be using it through standard def freeview or possibly the freesat tuner most of the time and Blu ray in the form of a samsung BD-P2500, although this would likely be upgraded if i was to keep the set.
I say "keep" the set as admittedly it may be too big for my room and the £4k value could be used elsewhere in my life if you know what i mean?!?
My other question is where do you sell such a beast? I wouldn't be confident putting it on eBay and I doubt local advertising would be any easier or fruitful...
I know a fair bit about TV's (I work for one of those larger electrical stores on you retail parks) which I know doesn't cut the mustard for some of you but I do try my up-most to keep up with the technology. Unfortunately my store is not deemed large enough to get on of these into stock so I need help in deciding if it's worth keeping or selling and buying something "better" and admittedly more suited sizewise. Providing I win of course. Not counting those chickens yet!
I'm coming from a Toshiba 37WLT66 so i suppose anything will be an upgrade!
Any help is much appreciated guys.
Cheers, Martyn
Cheers, Martyn
