okay - so I upgraded from the Sony STR-DA5200ES that has served me pretty well over the years.
I chose the award winning pioneer SC-LX82 (vs the new STR-DA5500ES). My first step before new speakers (i currrently have KEF 3005.2s)
However unless I can fix these basic issues I'm already having, i'll be sending it back - nothing on pioneer forums. I never had such basic issues with the Sony.
1) "HDCP ERROR" I have a kuro PDP-LX5080 and it doesn't connect due to a HDCP error! The messy solution is to seemingly unplug the Kuro HDMI from OUTPUT 1 (the Kuro link), Plug it in OUTPUT 2 which then works without error. One can then replug it back into OUTPUT 1 for a functioning connection!!!
To make it worse, if I then plug in the projector (infocus X9) it then re-triggers the HDCP ERROR message losing the TV again! Only if the projector is ON as well do both outputs work without the HDCP Error. I can then switch off the TV - What a disaster! and with a Kuro TV? An absolute mockery of dual outputs
2) PS3 (latest firmware(- this one is more tricky. Again never any issues on the 5200ES (i used a powered HDMI splitter before). The main XrossMediaBar screen is flickery and with corruption before blanking completely. A Blu-ray or videogame displays okay.. so I can only infer there is something about the main PS3 screen that after being fed through the SC-LX82 proves indigestible to the X9 projector (connecting the PS3 direct or via the DA5200ES provides no issues..)
Any advice for either of these would be appreciated. Now I know the 5200ES is prob two stars by todays standards (i read with much angst the other 5* vs 4* post) but it served me well and even though my neanderthal ears can pick out more detail with the new pioneer (i wanted networking + two outputs) I am regretting my choice.. - i just hope i am being dumb and the LX82 is still the award winner I bought.. help,
k
k
