- Aug 10, 2019
- 2,556
- 4
- 0
Based on the recommendation of Pioneer that the new DV-LX50 outputs 1080i via component video cables and my Philips HD ready multisystem TV (55" RPTV) accepts 1080i/480p and 576p, I bought one last week and hooked it through Rotel processor RSP-1068 to the TV by component video cables (earlier I was using a Pioneer DV-370 which outputs only 480p and 576p). Unfortunately the DVD player display always shows "PROGRSVE" which means the 1080i is not there. I have set the maximum resolution in the player at 1080i (though the table given in the operation manual of the player is confusing showing 480p/576p only for DVD when maximum resolution is set at 1080i). Does it mean the DV-LX50 will not give 1080i via component video? Or, is my system or setup at fault? Other users' opinions will be of great help.
Thanks in advance
murali
Thanks in advance
murali
