Tomorrow I am auditioning some Amplifiers - Leema Pulse, Arcam A38 and Primare i30 - one of these will replace my current Arcam Delta 290P. Not a problem with Leema as it has a phono stage, A38 can have a phono card fitted but the Primare would require a separate phono stage.
The Primare is already right at the top of my budget and their Phono Stage, the R20, is £500.
If the Primare wins out can anyone suggest;
a) A good match for it that costs (a good bit) less than £500
b) How much would I have to spend to get a phono stage similar in quality to the phono card in my Delta 290P. I have seen good reviews on here of the Cambridge Audio Azur 640P - the price is good but is it as good as the Arcam stage I am used to?
Any advice would be greatly appreciated - I don't want to rule the Primare out but I can't live without my vinyl - though I do only have a Rega Planar 3 and some of my LP's have now seen better days so anything too good may be wasted.
Many thanks
Penfold
Many thanks
Penfold
